Build advice
Should the pitch and roll be the same in all 3 columns. P I and d
Pitch and roll have the arrow.should I change super rate to be the same 68
It's up to you but I would try it. Then you can raise RC Rate by 0.1 until it feels right. I think there is a slight difference in how RC Rate and Super Rate work, but I can't remember what it is.
Hello another question. I'm using 1500 45c xt60 battery. Is it ok with such a big battery. I want to try my 4s 1800 45c what do you think. Thanks. Also I will post my pids later I think they need some changing. Flip and rolls a little slow
The small amount (if any) of flight time isn't worth the increased amount of damage due to extra weight
Thanks I used that battery because I have them for the qav 210. I checked my wizzard the super rate is both at 68. Thanks I'll try some changes when there is less snow on the field
Thankyy it flips and rolls fast now. Raised 1 like suggested. Also raised the slider bar to the right end but back a little. I never bury a control.my bat was 50%. Fresh batt and report later. Thanky
Reactions: theGreenOrange
No need to switch to a smaller battery. Flys fast . Flips rolls fast at 10 ft. Hovers steady up and down. Wow I'm more than impressed now.
Donrabeja
