Build instruction for realacc 210X
Dan@3DIM
Shetland Isles
I had been build many Radio control and this one is my first time self build drone and it do not come with instruction set up or manual book.. Where can I download one?
Ive been google for it and I only found one with many part for build 210x but I am deaf and close caption was bad and need fix. That the reason why I prefer book or PDF.
Dan,
I'm having a tough time finding printed documents for this quad. I would guess that your best bet is to read through this thread and ask those folks.
Realacc GX210 CC3D/Naze32/F3 Racer /w 700TVL Camera & 40CH VTX ARF/RTF - $103/190 - RC Groups
It's not really what you're looking for but here are a few other links to check out.
RealAcc X210 Tech Teardown & First Impressions - RC Groups
Realacc X210 214mm 3mm/4mm Carbon Fiber FPV Racing Frame w/ Matek PDB-XT60 5V & 12V
DroneHiTech.com – Buildlog: RealAcc X210 (QAV-X clone)
Reactions: Dan@3DIM
New to this sport, never flown or built before,I am sparing no expense in building two drones so I want to get this right. I am currently ordering parts to build my son a QAV 250r and I ordered a QAV x for myself. Below is what I have ordered for parts and I need some help with eCalc configurations to give me some specs on what I am building. I am looking for optimal prop size and pitch with the motor and size I chose along with optimal ESC to handle the motors on a 4s 95c 1300MAH Luminier battery.
OEM Lumenier QAV X and QAV 250r will have PRO Tmotor F40 2600KV motors, Kiss 30 AMP ESC, 4s 1300 MAH 95c Batteries, 5045/3 Props. I seeking to get out of the 250r to 80-90 MPH and my QAV X to 95-100 MPH if not faster with decent fly time!
My eCalc configurator shows that I am not even close to desired MPH and fly time for both QAV X and QAV 250r and shows my ESC’s, (KISS 30 AMP) are too small and I,need a bigger AMP ESC’s, it also shows my Pitch is way off and shows low MPH for both QAV’s. (I could be entering the wrong information based on lack of experience which is why I need your help)
Can someone configure both QAV’s for me and let me know the following
a) What optimal ESC and Prop size/Pitch would be for both build configurations and what prop would you sugest?
b) What Max Speed will be for both QAV’s QAV 250r for my son and QAV X for myself?
c)What is the fly time for each?
d) What is your experienced opinion about the Motors ESC, Battery and Prop selection I choose for each the QAV 250r and the QAV X builds. Is there a more efficient, more powerful lighter better combination you would have gone with to make each QAV sick performing drones? if so what would you have chosen?Please email me product info and why you would have gone that route so I can research and change products before I build.
e) What is it you would do to maximize each QAV with the Motor, ESC, Battery and Prop to get the most out of each QAV.
You can email me at [email protected] or text me at 989-359-1026 I will be building these QAV’s this week and parts are arriving dailey so time is off the essence and I need an experienced FPV Drone builder to help.
a) 5045 And 30A is a good choice.
b) not sure of a number, but it will be fast
c) about 6 minutes with agressive flying
d) your selections are good
e) they will be plenty fast as described. Your skills will take a while to grow into that level of performance.
I was just informed the Tmotor F60 2450Kv would be about 10-15MPH faster due to the bigger stator on the motor any thoughts?
Donrabeja
