Can't Plug Antenna into VTX
Looks like you just need to push the male mmcx into the socket all of the way. You'll need to get it perfectly square to the socket for it to push in.
Reactions: tevek
I tried that but it still keeps falling out. It doesn't feel like its locked in or anything at all - theres literally nothing to stop it coming back out.
Cheers
Then you aren't pushing it in far enough. It should "click" into place and then it won't fall out.
Reactions: okw and mrmund
I suppose you could be pushing it in all of the way but the ring is compressed and doesn't hold. (It looks like it should be OK in the picture). If that is the case... you might try this:
buck
