DJI Goggles 2
Anzacjack
There still seems to be a lack of better options for the Avata goggles. The standard padding is pretty uncomfortable and I thought after market options would have appeared before now
I know. These goggles are so much better than previous, but so uncomfortable. Its the only thing stopping me from flying more
The DJI website ha had advertised the foam padding ever since the Avata was released, however even though I ordered them back when I ordered the aircraft, they are still not available. Last communication I had with DJI they will ship in 3 weeks. It’s now Oct 22 this happened last week. However in the meantime I jury rigged the original padding from the fpv goggles and it actually works perfectly, just needs a little trimming in the nose area but actuallconforms nicely to the smaller size. I originally had it over the standard goggles 2 padding but it placed my eyes a bit too far from the lenses and also messed with the sensor so sometimes the goggles would not turn on right away and I had to fiddle a little, once I removed the installed padding and replaced with the fpv goggles padding it worked perfectly, confort and vision perfect.
Reactions: Halifax
Just ordered the "foam padding" from the DJI store. Hoping it will be like the foam padding that replaced the crap in the Goggles V2. We'll see....
Yep. From what i can see, its just the same padding as already fitted to the goggles 2. Its seems strange to me that decent after market padding hasnt been released yet. The last version of goggles had straps and padding made very quickly, and i dont think the original padding was as bad as the dji goggle 2. Hopefully someone will have something soon
Probably because all it took for the V2 was a bit of foam and a velcro while the Goggles 2 need a complex plastic part to clip in...
Reactions: mark426
Yea probably. Flew for a bit today with the avata. Had 6 students have a fly and all reported the uncomfortable nose. I may need to design something myself
It is exactly a replacement, just picked mine up today and I'm likely returning it tomorrow. This is what I ended up doing, works great. It's the original padding from the fpv goggles
Aliexpress has 2 different ones, ordered them both, due to arrive Dec 10. I'll post a review as soon as possible.
Reactions: Krrr
No i meant in your pics, you said you ended up using the foam from the original fpv goggles (i am assumig the V2s), how did you attach that. Or am I missing something
I'm using double sided tape. However I ordered one of the Ali Express ones that go over the goggles 2 padding, they look good and the price is also good. If they don't work I will probably look for a a more permanent way to glue the fpv goggles padding I'm using.
Reactions: afreakofnature
nemanja
