Eachine wizard x220 help
Thorndrone
Having trouble getting my new drone to start. Anyone know which pin on FSIA6B connector do I use? I’m not using the IBuS connector. Thanks in advance for any advice.
Not sure if this helps but have you flashed the FC and put betaflight on it, my drone was having trouble with connection. After I did this and set the board orientation to 270 it took off, then I crashed.
