Fluctuating voltage
spancs
Hello,
I'm flying the iflight DC5 titan with the DJI airunit. I had a crash which caused me to have to replace one of the arms. Since replacing the arm, my osd voltage readings have been fluctuating from 6v(incorrect) to 15.2v (correct). It changes in about 10 second intervals. It will spend 10 seconds reading at 6 volts on the osd, then go up to the correct voltage of 15.2 for 10 seconds, then back down to 6v, etc. I have tried this with 4 different batteries and verified their voltages with a multimeter so I am confident that their voltages are correct. the drone works and flies fine otherwise, but I don't want to fly it if I can't get accurate voltage readings.
Any thoughts? I would hate to have to replace the flight controller just to find out there was a simple fix that I overlooked.
Mfett
