foxeer predator cam
kobrakwad45
hello i am having problems with my cam / vtx i had to resolder and now the osd comes on and no picture when i press on the back of the camera the picture comes on with the osd is it the pins? is this camera damaged and should i replace it?
found a broken pin
Since it is intermittent when you apply pressure, and you have found a broken pin, it seems you have diagnosed this issue. Best of luck getting things sorted out!
Reactions: kobrakwad45
captadam
