FPV settings
murietamike
I have a fpv combo. I've had it for awhile but noticed after running it through DJI assistant my only channel selections are 1 & 2. no #8. That is in transmission under the pilot. The RTH and max altitude are in meters although I have imperial selected. The main screen shows MPH ok.
Then under settings, about it has a switch to dji digital fpv system. That shows me a whole different menu with 8 channels but I lose picture from the drone. Help please! Thanks
You need to reduce the bandwidth setting to get more channels. By default it uses wider channels so there are fewer of them.
