Hello from MavicPilots
Cyberpower678
I'm a total noob and just built my first racer. The next steps are to tune the PIDs. As I never done this before, I would appreciate some insight. I'm using betaflight on an F7 controller.
From what I understand P is stick responsiveness, I is how stead the drone is in flight, and D helps to control the oscillations. Do I have this correct?
Welcome to FPV and the forum. Is there a reason you feel you need to tune? That board/gfu should have a great stock tune. If you have oscillations, it may not be due to tune. This video is one of the simplest tuning videos i've seen
Maybe. I haven't actually tried to bring it up into the air just yet. When I applied minimum throttle, the motors turned on and off so quickly, it rattled the screws out of the motors. Yikes. Maybe my throttle settings are a bit off?
Also, if you have your flight controller orientation wrong, it'll go nuts. You can set the orientation in betaflight under configuration, if i'm remembering right. Been a while since i've used betaflight. I use raceflight
I did definitely make sure that the orientation is correct, I'll check the reciever endpoints. I use SBUS though.
Sometimes with no props, they'll act funny. With a finger on the arm switch (you can set arm to a switch in betaflight), try it with props on outside, just make sure you can quickly disarm it
Will do, but I won't be able to report back until tomorrow. When it rattled some screws loose, I lost them. Getting more tomorrow.
You can use two screws per motor, its all i ever use. Good luck, let us know how it goes. The first build includes a large learning curve but is well worth the trouble
Haven't seen much on the snail, it shouldn't be the problem. Set your endpoints, set a switch to arm/disarm, put some props on it and go outside for a test, just make sure you can disarm quickly
Michaelashast
