Sorry for getting in the middle of your conversation, but may I ask you why you downgrade the firmware to 01.02.00.00?My drone and goggles were in 01.02.00.20, I downgraded all to 01.02.0000 using DJI assistant 2.
Maybe try to update first all your devices with the lastest firmware 01.02.00.20 and to downgrade all at same time.
Sorry, I'm still clueless.I see! Very good point.
thanks.
That won't work.My drone and goggles were in 01.02.00.20, I downgraded all to 01.02.0000 using DJI assistant 2.
For the hack...??
No idea what this means.
Thx,
TCS
It’s the power hack by adding a simple text file that opens up more power levels for the DJI FPV goggles.Sorry, I'm still clueless.
For the hack...??
Thx,
TCS
Do you know if you can go up from 01.02.0015 to 01.02.0020 and then downgrade to 01.02.0000? If possible does that need to be done with AC also or can I just do the Googles using computer?The dronehack software lets you download and flash whatever firmware.
DONT install 1.02.0015 as it has a block for downgrading.
Do you know when the 0015 came out? I am thinking about buying a 2nd set for audience mode but I presume I have to put 0000 on it to work with master and ac. Also, can I activate with whatever fw I get or will it make me update to 0015?DJI made a mess of the version numbers, so no even if the number is lower on 0015 that's the "newer" one and has a higher antirollback number.
0015 will not let you go to any other version sorry. Once you’re there you are screwed.Do you know if you can go up from 01.02.0015 to 01.02.0020 and then downgrade to 01.02.0000? If possible does that need to be done with AC also or can I just do the Googles using computer?
Is the FW marked on the box if you buy just the Googles V2? or is it only date of production just like when you buy a set0015 will not let you go to any other version sorry. Once you’re there you are screwed.
Not sure sorry threw my box away a long time agoIs the FW marked on the box if you buy just the Googles V2? or is it only date of production just like when you buy a set
I was just thinking about taking my chances with BestBuy. Thanks!Don't think anything's marked. Buy from a place where you can return them...
