How to upgrade DJI googles to V01.02.0000 and not to V01.02.0020?
opoch9
Any way to flash the firmware to V01.02.0000 using a Windows 10 Computer. My Drone is that version, but DJI Assistant 2 (FPV) 2.1.2 only allows for V01.02.0020 for my googles.
My drone and goggles were in 01.02.00.20, I downgraded all to 01.02.0000 using DJI assistant 2.
Maybe try to update first all your devices with the lastest firmware 01.02.00.20 and to downgrade all at same time.
Sorry for getting in the middle of your conversation, but may I ask you why you downgrade the firmware to 01.02.00.00?
Thank you!
Sam
That won't work.
Okay found it. Wasn't easy, but there is something that can help.
Hint: Harry Potter character
The dronehack software lets you download and flash whatever firmware.
DONT install 1.02.0015 as it has a block for downgrading.
Do you know if you can go up from 01.02.0015 to 01.02.0020 and then downgrade to 01.02.0000? If possible does that need to be done with AC also or can I just do the Googles using computer?
DJI made a mess of the version numbers, so no even if the number is lower on 0015 that's the "newer" one and has a higher antirollback number.
Do you know when the 0015 came out? I am thinking about buying a 2nd set for audience mode but I presume I have to put 0000 on it to work with master and ac. Also, can I activate with whatever fw I get or will it make me update to 0015?
0015 will not let you go to any other version sorry. Once you’re there you are screwed.
Is the FW marked on the box if you buy just the Googles V2? or is it only date of production just like when you buy a set
Don't think anything's marked. Buy from a place where you can return them...
Ya. I wonder if the people who did the root exploit will root the drone. Being able to tune PIDs and **** would really change things up.
Kylst18
