iFlight DC5 Drone Day 7 - Series Final
Hummingbird.UAV
Alberta
www.youtube.com
Last series post for flying the new drone. Got a little disoriented at the end and did a tail slide into some trees. Hard to believe how fast this machine is. At half throttle it will be going 93 kph. (26 m/s) Onboard video recording failed again. Will format it in the air unit and hope it solves the problem.
Reactions: ebeez
Maybe a desync there when you went zero throttle. Do you have dynamic idle set?
You might find this useful
Yes I have dynamic idle set. Did look at the log file and with the throttle at 0 and the other stick centered one motor is at 100%. I adjusted my ESCs as per the info in the video. Thanks for your help.
fpvtune
