Loose antenna mount
Gin
Hi everyone, so i finally hot into fpv and in my very 1st Flight i got problems, One of my antenna hot sucked into a propeller, than i fixed the antenna and mounted in a differenti way and that worked out but i May Need to get a Crossfire module cuz the enviroment where i fly it's causing me some loss of signal, now the Crossfire micro ex antennas are way longer and i font know if i Can cover them with something to get them stiffer and mounted them somehow.
I'd Like your experienced suggestion
Thank you for your help
You want to heatshrink your antennas to a zip tie. I put a layer of heat shrink on the antennas, and then I tape them to the board to make sure the heatshrink is taking the force, not the antenna. Rout them to the zip tie, and heat shrink them on. I use a few layers of different colors, that way prop strikes are really obvious, and you can see how deep it went (but I fly rough and crash a lot)
ok thank you very much so i can heatshrink even the last part of the antenna that's good i'll do that, thank you again for the fast response
Reactions: rtkDarling
