P value dropping to 0
Torc
Cincinnati
www.youtube.com
FC: Eachine AIO Pro F3 Brushed
Betaflight: 3.4
The kwad had the wobble of death when I got it back together and did a test hover in the house. Did a reset of the PIDs and took it out for a test flight.
The next day I went in and updated the PIDs to my preferred settings (80,50,120), saved and did a short flight in the living room. It went well for a minute or two, then it went into the wobble of death and crashed.
I checked PIDs and P for Roll and Pitch were at 0. Rinse and repeat and the same thing happened. I tried one more time and when it happened again the P was lower than my setting and of the default.
Any ideas what would be causing this?
Bad flash? Try re-flashing (with the previous flash if the current is new) Also, check the fc's pdb for solder splash if you have done recent soldering
Also, make sure you are flashing the proper program for your particular board
Reactions: Wayno52 and RENOV8R
That's the oddity, all that changed was that I took it from one frame, where it worked fine to another where it started acting up.
captadam
