Receiver Mounting
Hyper-C
I"m using a FrSky R-XSR Receiver, but I think my question applies to most receivers.. what's the best way to attach the receiver to the frame? I"m currently using double sided foam tape, but that doesn't seem to do a very good job, and the receiver ends up being held on by the antennae that are heat-shrinked down, which can't be good for it.
Any suggestions on the best way to mount those?
Once you have you R-XSR wired up, cover it with shrink tube. It'll stick much easier, I usually just stick it on top of the FC. just don't forget to cut out a small square in the corner for the bind button
Jaapio
