Dave,
Take your MutiMeter and put it on resistance, when your probes are in the air not touching each other it should show something like O L. You do not connect the battery for this test. Touch the negative probe to the negative lead on the Lipo connector, take the positive probe and touch different spots on the frame. Sometimes you have to press hard, almost scratch the frame to make a good contact. The best place to do it is along the side of the frame, where the carbon sheets are laminated together. If your meter shows anything other than O L, you've got a short somewhere.
