rpm filltering
Kendrick95
hi all im having alot of prop wash so other than rpm filltering im trying to lower the fillters too and when im going higher than 1.3 im having some weird vibrations on a low speed cruising but when im on a higher rpm i dont get any vibrations
my set up is:
t motor f60 pro iii 2700kv
mamba f405 mk2 escs and fc
any one have a solution to the vibrations? i know when I'm lowering the filtering the gyros are more sensitive to noise but why does it happens on lower speeds?
maybe if my antenna is a little shaky because i have a tpu mount for it?
thanks
Did you ever run this quad on BF4.1 without filtering?
Untill now I was on bf4.1 but on default filtering then I try playing a little bit with the filtering I'm having a smooth flight I'm having a problem only with the prop wash the drone really uncontrollable when it happens.
Kylst18
