Setups
racin44
I'm having issues with 1 of my drones. I use betaflight. For some reason when I let the controller stick go, it won't re self-level. It keeps going in that direction. Im not big on knowing all the pid's and beginner settings. Any help would be great.
Thanks for the help, flies better but it's trying to relevel too fast. In other words, it wobbles side to side.
If it's oscillating you'll likely have to find yourself a gain tuning tutorial and go through the process.
Reactions: Keifie
I did a bit of research, still working on that quad. I pulled out my other one that uses skitzo and flight one. That one flies great. So I will be trying some of the settings across the other for starting. Attached are both my builds. I have another I made from scratch, but needed to use parts from that one to keep my others going. The 2 I have I bought as frames only. I added all electronics 1 at a time. I use emax motors. I like those the best. Thank you for all the help you all give me.
buck
