TinyHawk II FC wont turn on. Does connect and has power
mdethmers
Hey all, I was setting up my TinyHawk 2 FC, which I had just received new, after which it decided to turn off and never go on again.
I was soldering the motor wires and installing a flysky a8s receiver to the RX2 port, and was busy setting up the controls of the transmitter after;
  1. The quad started beeping continuously
  2. I unplugged the battery
  3. I replugged the battery
  4. There are NO status lights on the FC anymore (no blue, no red, no green).
The motors give 3 beeps. I still get a video signal. The received gets power. I can still connect to Betaflight (and even flash new firmware), but I see a gyro not found and RX not found error, and the FC seems to be not functioning anymore. Has anyone experienced this before? There was no short afaik, as I was already getting up the last elements of the transmitter.
Note; I did have the board conformal coated. This is the 2nd conformal coated board that died on me. Does anyone know if this can be the cause?
reflashing does not work, i have the same issue, i accidently wired the camera wrong and i get no power to the fc but it still connects to beta flight. everytime i try reflashing, i get the same error message regardless of what i have tried, "no response from bootloader programming failed" of course when i google that message it keeps telling me to check the cable or check my drivers which would be useful information if i was getting power to my fc.
TomasZaTo
