Trottle problem
Rio9112
Hey im new to drone and i have a probleme might be a small problem but cant find !! When i start de drone everything is ok as soon i give a bit of throttle seem to go full throttle after a low the throttle in nutral position it always going up whitout touching the throttle stick please help
Tanks pierre !!
Have you connected to cleanflight or betaflight? You should check the yaw orientation of the flight controller. Also check throttle response for direction on receivers tab.
Tanks pierre !!
Check your end points on you throttle in betaflight or whatever your running.
Reactions: theGreenOrange
Tanks for the help i calibrate the esc and work fine now fly 15 without problem and crash
adax
