wibo33
Recently I flashed the Betaflight firmware to my Flip 32(REV5, 6 DOD) board.
The flashing procedure was succesful.
I connect the board, there is connection.
Now in the SETUP I want to calibrate the accellerometer., the colour of the yellow block turns into white for a very short time. Then again into yellow. Every time again when I try).
So think no calibration has taken place.
Also the calibrate magnetometer block is gray and so not available.
I wonder kow can I solve the problem.
(exact the same problem I have with another NAZE32 board)
Do you have them enabled? Or are they shut off?
They were not enabled. I enabled them but there was no difference.
So it did not solve my problem.
Then your going to have to do it in the CLI.
Set acc_hardware=0
Set mag_hardware=0
Here is more info if you need it.
Betaflight specific CLI commands · betaflight/betaflight Wiki · GitHub
What version of betaflight are you using? I'd recommend if you don't really no what you're doing switch to cleanflight it's more ironed out. Betaflight is still under development and is more for pilots who know what they are doing.
Reactions: QuadCopter102
very confusing indeed !!
set acc_hardware = 0 zero is an invalid value !
set mag_hardware = 0 invalid
see; get acc
get mag
My firmware is Betaflight _3.1.0
I see the CLI commands are different from older firmware.
I have to set it to Default(is on, "0").
Unfortunately it did not solve my problem.
sanykcz
