- Joined
- Feb 8, 2021
- Messages
- 22
- Reaction score
- 2
- Age
- 24
So I was flying the drone and the balance connector went through the rotors causing some of the leads to short. Seeing as I need a new set of underwear after the experience do I need to buy a new battery aswell? All the cells are at a good voltage - about 3.7V each so can I just resolder them onto a new jst-xh connector like this JST-XH 2S 3S 4S 5S 6S LiPo Balance Cable Charging Power Wire 10CM
It has no signs of swelling or damage otherwise. Also how do you work out which cell is which? I just used the multimeter and found the cells with 3.7v between them. Is there any other way to double check? Presumably its quite important to get right.
Cheers
Cheers
