I just received my Lizard 95 and tried to set it up.
So I configured all the usual stuff in betaflight which worked fine so far.
Once I finished and tried to arm it, it didn't arm but started to beep (see in the video).
The aux is configured correctly and works in the "modes" tab.
I enabled airmode so the props should start spinning when I arm it. They also won't when I add throttle after arming.
Motor stop is disabled and throttle is below min_check. The motors work when testing them in betaflight.
I uploade the video here: IMG_2265.MOV
