Micro SD card compatibility issues.
Oarmaster
For some reason my TV (Roku media player) will not read the micro SD card out of my fpv drone or the card out of the V2 goggles. I adjusted all the settings in the camera drop down without success. No issues reading my micro SD card from my Mavic or my Mini 2. Any
Ideas?
I don’t know if it is related, but I have 3 Windows machines that don’t like the cards coming out of the goggles. (I have to repair the cards before mounting them.) I don’t have the issue with the cards from the quad. DJI says they replaced the micro SD slot on my goggles but I have the same issue.
I mention this because perhaps the issue would cause the symptoms you are experiencing with your TV.
Good luck!
For the aircraft card you probably need to record h.264 and not h.265, and possibly lower the quality to 1080p60 as those media players often don't support 4K at >30fps.
The goggles record at a non-standard resolution so it probably doesn't support that either.
Reactions: bluesgeek
powgoesthecow
