R-XSR Lua Scripts
NathanJ529
I'm trying to set up lua scripts on my x-lite but I keep running into an error.
For the x-lite, to get to the betaflight script you have to hold the menu button down, when I do that it tells me to use the tools menu.
In the tools menu, I hit betaflight config, then it gets stuck on initializing. From what I've read it has something to do with not receiving telemetry from the r-xsr, but the radio IS receiving telemetry.
I'm guessing it might have something to do with the R-XSR firmware, it's on "RXSR_FCC_ACCST_19112.fr" which I believe is like 2 years old.
I'm using that because I've heard the newest FrSky firmwares are a complete mess and one update had a chance to brick your receiver.
So I guess my question is does the firmware not support Lua script through s.port? Would flashing the latest firmware (RXSR_ACCST_2.1.0_FCC.frk) fix my problem and not brick my r-xsr?
Also for reference, the x-lite's internal module is on firmware "iXJT_NonEU_20180416.frk", I believe it's compatible with the latest r-xsr firmware.
viktor.rybk
