Ruko F11 Pro Arm Replacement Issues
mlooney2016
Hi, I replaced one of the damaged arms on my Ruko F11 Pro Drone. When I attempt to start the motor, the replacement arm motor spins a half turn a few times and then stops completely. The other arms function fine. Any thoughts about why this?
Was the motor damaged along with the arm? If so, it may need to be replaced as well.
So likely either one of the motor connections isn't made properly or the ESC is dead too.
The arm included a new motor
If you have a volt meter, check the voltage going to each motor. As Kilrah said, you may have a dead ESC
Thanks for the response. I took the drone apart and found that one of the wires I soldered became disconnected when I put it back together.
Reactions: GFields
rockercoaster
