adding a lost model alarm
Ray1609
hi, me again!
after spending ages walking around the field looking for my drone, I have decided it is time to fit a lost alarm.
I have a spf3 flight controller, which has to holes where I could solder some wires too, but I have noticed some buzzers have 3 wires on a plug that would match the speed controller outputs...
how do I programme it in cleanflight to run from the 3 pins rather than soldering more wires as that's my weak point?
or have I got the wrong idea of all this.
thanks
Ray
brilliant,
thanks for the help :)
I really should put a build thread up soon!
Ray,
I really wish you would. I think it's interesting to see what others are doing and what they're encountering. I've put up a few but they don't seem to get much play by other members.
Ray,
That's because theres really only like 5-6 active members in here.
How does a buzzer work if the quad is "misplaced" and if you didn't program a switch to activate it?
Lost in the grass and you're looking for it....
The buzzer can be programmed to activate when there is a lost signal without activating a switch. Many ESC's can be as well.
Reactions: Serius
Ohh ok..Thanks Jerry
RFPV
