Crashed my Crusader GT2 into snow
Mars
Hello guys,
i did a mistake and disarmed my drone over a field with snow.
I found my drone with much snow on it, i disconnected the battery emidetly and putted the snow away.
After i tryed out if the drone is still working, the video signal worked but i got the message from my transmitter, that there is low rsi signal. I tryed to arm the drone, but it didn't work.
At home i tryed to connect my flightcontroller to betaflight, and it also didn't work.
Please guys i really need your help, i'm new in fpv and it is my first drone. It seems like my motors and ESCs are still working but maybe the reciver and my board are dead, i think a little bit of snow was on the board and it is not covered..
What do you guys think?
Thanks for your help!
Best regards
Marius
Is it totally dry? sometimes it takes a while to dry. Use a hair dryer or something but don't over heat it
Yes i think so, i also think there is some rest of dirt on the board which could be an issue.
I already connected a battery to test if the motors will arm, could that be a bad thing?
just_labrone
