Frsky R-XSR Bidding Issues.
rabbizera
Hello everyone.
I am brand new to FPV and after some (a lot) of practice on simulators I finally bought my first real quad. However, I am having problems with binding my Taranis QX7 to my brand new Frsky R-XSR.
The issue I am having is basically that the receiver does not go into Binding mode. When I turn on with the FS button pressed all three LED lights are constantly on (RED, GREEN and BLUE).
I have updated both the receiver and the controller firmware to the latest versions but nothing has changed. I still get all the three solid lights instead of the blinking red light that is supposed to happen when you enter in binding mode.
Any ideas how to fix it?
What do the LED's do if you power up without pressing the bind/FS button? You need to check and see which radio you have by looking in the lower left corner of the display, does it say ACCESS or ACCST? And what exact revision did you put on the radio and RX, need to know the OpenTX rev, the Internal XJT rev and the FW rev you put on the RX.
Henk1010
