Pids flip and roll
Davey
Nj
Hello I raised my flip/roll pid. Also raised rate and super rate. Wizzard flips and rolls a bit past. I didn't touch p i or d any sugestions
Have you updated firmware recently? This happened on my son's X220 when I did that. The reason is that the board's orientation is turned 90• in the counterclockwise position. The firmware must reset the FC orientation back to facing front. So I found that out and had to return the yaw offset back to -90• in Betaflight. Quad flew good after that.
captadam
