FrSky Taranis QX7 not binding with Tinyhawk 2 D16 (solved)
ruaidhri
Hi All.
looking for help from anyone that had this issue or knows a solution.
Just received my first fpv so excuse my ignorance in all this! I am trying to learn guys.
I have a FrSky Taranis QX7 - eu lbt - I updated Opentx FW today (ver 2.3.11)
Tinyhawk 2 connected to betaflight and in cli set to bind.
on the x7 my binding settings are:
Internal RF Mode option: XJT D16
CH range: 1-8
I try to bind Ch1-8 Telem off
Nothing happens.....
Any ideas what im missing or not doing correctly?
Thanks in advance for your help.
Rory
The Tinyhawk 2 has a built in Frsky D8 reciever. I had a similar problem yesterday. After updating OpenTx I only had the option of FrskyX. Once I selected that I went to the line below it and scrolled through and an option for D popped up. I selected that and I was all set.
The channel range option is something else. I'm new to OpexTx so I'm not sure exactly what it is yet but I believe it has to do with running multiple reciever
Yesterday I posted a question because I couldn't find the option for D8 and received this reply from Kilrah.
"D8 is now one of the options under FrSkyX instead of a separate top level choice.
FrSkyRX has nothing to do with it, it's to use the module as a receiver."
Thanks,
Were did you select D8? under internal or external RF on the controller?
My radio has an internal module and that's the one with the Frsky protocol.
The external would be for something I added to the bay in the back like crossfire.
Reactions: ruaidhri
OK, I got it.
I did try a few things above and one thing that I also noticed was that in Betaflight there was the option of FRSKY_D or FRSKY_X (i had this at X) but then at the bottom of the list there was another for FRSKY_X_LBT. I changed it to FRSKY_X_LBT then it Bound on XJT D16.
All good. and just back from my first flight!
Thanks for the help.
Cheers
Reactions: mrmund
TomasZaTo
