Mobula7 HD cable detached
thedroneracingpilot
Hi,
The other day when I was changing the battery of my mobula7 HD I unintentionally pull the cable and it got detached from the white PHR2.
I have zero knowledge about electronics but I believe that what I need to do is as simple as buying a new pin then connect it again.
My questions are:
Is there any other solution?
What's the name/size of the pin I need?
(I went to a couple of electronis stores but they did not have the pin and they did not know the name/size)
Pretty sure it’s a PH2.0 plug. I would grab some tweezers and a small screwdriver and simply reattach the wire and insert it back into the plug.
Or if you want to run 2S, de-solder the wiring from the board and swap it for an XT30 plug (you can buy them preassembled) and run one piece 2S batteries.
Reactions: thedroneracingpilot
LonaS324
