WHAT I LEARNED ABOUT RACE QUADS TODAY
Jerry,
I saw a couple vids on YT and its not hard...i really need to trust my equipment. I know you guys understand that.
If i get in there and its to confusing or the vids don't represent what i see ill close the thing up and rest. Been doing drone stuff since the 11:45...
Keith
I could not make it work... my db's jumped ten points...no response from the bird...i tryed ...it didn't work out. Great idea though.
New one here Tuesday before noon.
The peaceful moron
No i did not know that the shield wire was involved...
Which one is the ground do you think?
The larger pad is toward the inside of the board...the small pad is near the edge...any help?
It looks like both are ground pads. Split the braided shield into two halves, twisting them into basically what is one "wire" on each side. Solder one to each pad.
In your original solution..and which one is the raw coax. Or does that get split as well>?
Split the coax and the braided shield twist each pair together and solder 1 twisted wire to each pad?
That looks like the shield goes on 1 no the inner cable goes on the other?
So i can put the shield on 1 pad and the inner wire on the other...correct?
undeze
